OCIO settings in Houdini 20.5.613 and UDIM materlials
   734   0   1
Hi, can someone tell me what the problem is, I'm trying to add a rule in OCIO settings so that raw files are immediately correctly selected in the correct color space, but as you can see in the screenshot, I don't have this option, or this config immediately translates everything to ACES space.
Also the problem is that Arnold is not pulling up UDIM material data correctly. Although when assigning I select the correct color space in IMAGE ( Utility - Utility Raw).
On the first screens, what I have proisidutsya, the second screens, how poideya should be, the last is the behavior of Arnold in Solaris, I want to note that when using textures are not raw, everything works fine. The problem is not in Arnold himself.
Скриншот 02-07-2025 10.40.56.png (990.1 KB)
Скриншот 02-07-2025 10.43.45.png (74.5 KB)
Скриншот 02-07-2025 10.44.30.png (306.1 KB)
Скриншот 02-07-2025 10.44.50.png (364.8 KB)
Скриншот 01-07-2025 22.06.08.png (1.8 MB)
