How to make these boxes connected via chains?
   667   1   0
I need a bit of help here, so these cubes are meant to be floating islands. I want it so that these islands are like, connected to each other by cables, or points. Think of it as like, floating islands with chains. But the issue is, I don't know where to start! 😅
Optionally I would like to know how I would make it all connect to a single island too.
Any help would be appreciated! 🙏
Here is the reference picture:
Screenshot 2025-07-16 143710.png (1.5 MB)
One way to start is to scatter a single point on each box, then create a two-point line between them. From there, resample the line to make more points. Pin the "root" and "tip" to each island and run the newly created line through a vellum solver to have gravity affect the droop.
Just one way to start.
You could review the cable tool tutorial.
https://www.sidefx.com/tutorials/project-titan-cable-tool/ [www.sidefx.com]
Here's a couple of possible setups.
Edited by Enivob - July 16, 2025 09:52:37
ap_DQ_cables_hang_from_ceiling.hiplc (100.2 KB)
ap_vellum_two_point_hanging_cable.hiplc (531.4 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
