Houdini 21 Sneak Peek
   34232   61   6
Full list of features (based on what was legible in the video):
KineFX: APEX-driven Rigging and Animation
  • Production-ready for all riggers and animators
  • Additional auto-rig components e.g. limb, hand, foot, neck, scapula, ulna
  • Spine rig component v3.0 with interactive squash & stretch and more
  • Enhancements to reverse foot, including rotational toe control
  • Fast, interactive and easy to use rig builder with viewport drag-n-drop
  • Ability to rapidly build complex facial rigs with blend shape support
  • Simplified procedural auto-rig component creation based on graph fusion
  • Updated Electra rig with twist joints, reverse foot, clavicle, bendable IK/FK
  • Fully rigged realistic human: Otto v1.0
  • Many enhancements to APEX graphs and APEX scripting
  • Fast in-place APEX cooking of SOP verbs, similar to compiled SOPs
  • Convenience nodes for converting KineFX characters to packed folders
Ragdoll and Constraint Enhancements
  • Streamlined ragdoll configuration workflow
  • Ability to animate ragdoll stiffness, damping ratio, rest length and more
  • Revamped constraint system with support for multiple concurrent constraints
  • Soft and hard ragdoll tether constraints
  • Parent, Static and LookAt constraints
  • Automatic constraint offset controls
  • Option to create custom constraints and build on top of standard set
  • Ability to add keyframes to mirrored controls automatically
  • Full-body IK posing with high-level targets for streamlined animation
  • Ability to inherit animation layers from upstream APEX animation nodes
  • Hotkeys to grow and shrink a selection of controls
  • Unified and streamlined keyframe baking workflow
  • IK/FK switching
Animation Tools and Graph Editor
  • Playbar Ripple tool to move all keys before or after cursor location
  • Enhancements to selection sets e.g. rig control management and display
  • Hotkey-driven rig control pick-walking with topological heuristics
  • Ability to hide rig controls when scrubbing and dragging
  • Animatable rig control feedback e.g. shape and color
  • Posing with invisible controls a.k.a. direct skin manipulation
  • GPU-accelerated skin and blend shape deformation in future production build
  • Customizable look-and-feel of standard 3D handles
  • Rewritten audio subsystem based on FFmpeg with smooth scrubbing
  • Scene Add Prop node options for animated and deforming geometry
  • Animation transfer with APEX Animation from Skeleton
  • Up to 6x faster panning in the animation Graph Editor
  • Completely redesigned Animation Catalog a.k.a pose library
  • Motion Mixer (beta) with tracks, clips, NLE-style GUI and native APEX support
  • Motion-mixing of arbitrary APEX rig controls, not only skeletal animation
  • Fully-featured APEX animation environment available as a Mixer effect
  • Built-in support for ML-driven skin deformation with custom training recipes
  • Neural Point Surfacing: ML-based point cloud surfacing for enhanced realism
  • Support for AMD® NeuronNet backend and new hardware
  • Hand motion tracking using deformable volume capture
  • Ability to convert tracking data to joint-based retargeted motion
  • glTF importer for character, animation and skinned geometry
  • Countless UX improvements across the board
CFX: Organic Tissue Simulation (OTiS)
  • Robust, GPU-accelerated Organic Tissue Solver for muscle and tissue
  • FEM-level physical quality and faster than Vellum
  • Simultaneous, fully coupled muscle and tissue simulation
  • Robust volume-based muscle & tissue collisions immune to initial intersections
  • Muscle and tissue configuration nodes redesigned for ease of use
  • Reengineered tissue mesh generation allowing for robust fat-muscle collisions
  • Otto: humanoid rig with bone geometry and full muscle and tissue system
  • Ability to transfer full muscle rigs and bone geometry between characters
  • ML Deform model trained on Otto’s muscle system
  • Real-time APEX animation of ML Deform-trained characters
  • ML Train Deform recipe to facilitate training with user data
  • Armature system for quasi-static muscle capturing, simulation and deformation
  • Armature Deform node designed for data training for ML deformation
  • Organic Deformer node to minimize tetmesh energy for improved accuracy
  • Muscle Deintersect node to remove small intersections
  • Ability to blend overall activation in Muscle Flex SOP
  • Automatic muscle-to-tension line matching and multiple lines per muscle
  • UI/UX enhanced Muscle Constraint Properties node
  • Muscle Tension Line Activate node for procedural and user-friendly activation
  • Muscle Auto Tension Lines for easy, procedural definition of tension lines
  • Muscle Adjust Volume to control muscle mass with collision support
  • Many functionality enhancements to Muscle Solidify
  • Remove Fat node to control how fat tissue influences muscle transfer
  • Tenfold speedup of procedural fibre direction computation
  • 3–4× faster tetrahedral conversion
  • GPU-accelerated edge relaxation with surface sliding support
  • GPU-accelerated delta mush
  • Fast grooming with Parallel Transport Along Geometry
Grooming Tools
  • Guide Clump Center to generate center lines of hair clumps
  • Guide Surface to generate triangle surfaces over hair grooms
  • Guide Fill to populate empty points on guide interpolation meshes
  • Guide Find Strays to identify and group stray hairs for downstream grooming
Geometry | Modelling | Environments
  • Powerful shot sculpting toolset with NLE-style GUI for character finalling
  • Elastic Deform, Plow and Planar sculpt brushes
  • Option to sculpt using surface distance falloff
  • Convenient in-node management of sculpt masks
  • Ability to extract geometry contours procedurally with frame coherence
  • Unsubdivide node to reduce the resolution of previously subdivided meshes
  • Improved Paint SOP performance with geometry groups
  • Enhanced Texture Mask Paint w.r.t. UDIMs, alpha and mask flattening
  • Bidirectional ray support and options for group transferring in Ray SOP
  • Ability to model branching curves as well as cutting and joining curves
  • Adaptive quad remeshing for improved results on organic geometry
  • Procedural and interactive edge flow control in quad remeshing
  • Support for the @ attribute syntax for vertex groups
  • Many enhancements to Poly Extrude SOP
  • Ability to un-overlap pieces of geometry identified by string or int attribute
  • Ability to use UV Fuse in compiled blocks for faster performance
  • Versatile UV map generation with UV Flatten from Points SOP
  • Topological sliding guided by curve references
  • Edge relaxation node to match reference geometry
  • Extrapolation enhancements to attribute filling
  • OpenCL topology bindings for half-edge attributes and tetmesh adjacency
  • OpenCL-accelerated attribute sorting
  • Multithreaded geometry sorting
  • Redesigned, COP-powered hydraulic terrain erosion with simplified controls
  • Option to output erosion sediment, flow and debris
  • Neural brush-based terrain generation with trained models in Content Library
  • See also scattering tools in Copernicus
Pyro | Crowds | RBD
  • Rich set of pyro recipes such as thruster exhaust, fire portal and wispy smoke
  • Fast, accurate and frame coherent ML-based pyro upres node
  • ML Train Volume Upres recipe for user-specific scenarios
  • Gas Remap node to shift and scale a scalar volume field into new range
  • Gas Burn node to control flame field dissipation and emit smoke and heat
  • Enhanced turbulence controls in pyro solver
  • Partitioning of large point clouds to execute efficiently on OpenCL devices
  • Ability to blend between animation clips based on crowd agent’s turn rate
  • Support for parent-child agent setups via crowd motion path toolset
  • Easy to use fracture-and-destruction system built into dynamic car rigs
  • Options for fans and propellers to support spinning parts in motors
  • Easier to have vehicles jump off the ground at specified locations
  • See also Otis solver in CFX and COP solvers in Copernicus
  • Bullet solver v3.25
MPM | Whitewater | Rendering
  • Joint-guided region extraction for quaternion blend weights
  • Stable pre-simulation region propagation and region masks
  • Updated online terrain stamping for localized simulation
  • Auto-inferred sensor fields that understand and react to environments
  • De-stabilized gradient field moments and ramp shapes in colliders
  • Dedicated MPM state for easy access to all MPM substeps
  • Lighting export enhancements for USD/Hydra
  • Multi-faceted enhancements to post-simulation pipeline
  • Surfacing node to efficiently generate render-ready geometry
  • Surface tension support for realistic liquid behaviour
  • Debris emission for secondary particle simulations
  • Deterministic particle-to-grid option for reproducible results and speed
  • Ability to emit particles on top of existing particles to fill MPM container
  • Support for the 'age' point attribute in MPM Source
  • Ability to add upper and lower padding to MPM container
  • Dedicated nodes for streamlined post-simulation processing
  • Specialized post-simulation nodes for stiff material destruction e.g. metal
  • Dedicated whitewater shader
  • Direct rendering of OpenVDB points
  • Accelerated motion blur rendering of VDB volumes
  • Volume shadow step rate control for better performance
  • Native support for integer and vector volumes
  • Support for USD colorSpace metadata on material parameters
  • Automatic exporting of basecolor AOV
Karma | Husk | XPU Rendering
  • Faster and more memory-efficient rendering of subdivision surfaces
  • Feature shader outputs for GL/GLSL/SSS in viewport
  • Faster Flip/Volume viewport preview
  • Improved OpenGL selection performance
  • Vertex displacement motion blur with velocity-aware shading
  • Rigged object motion blur enhancements and instancing optimizations
  • Ultra Path Tracer support for geometry visibility through thin matter
  • Synchronized nested dielectric priorities between CPU and XPU
  • CoordSys primitive discovery
  • OIDN denoiser v2.2.1
  • Ability to denoise with CPU only
  • Automatic switching to bucket mode when rendering deep images
  • Husk support for render pass specification
  • Render stats and Husk information included in deep image metadata
  • Support for custom metadata in render products and AOVs with Husk
  • Improved handling of deep image RGBA channels in Husk
  • Ability to assign default render delegate to Husk
  • Husk auto-tiling, including deep image support
  • Husk support for viewport render delegates such as Vulkan
  • CPU: GPU-accelerated texture baker — see also Copernicus
  • CPU: High-quality non-photorealistic (NPR) outline generation
  • XPU: Precompiled render kernels for faster startup
  • XPU: Optimized compilation of user-defined shaders
  • XPU: Volumetric light support
  • XPU: Uniform volume rendering that matches the CPU renderer
  • XPU: Support for partial opacity in conjunction with background holdouts
  • XPU: Ability to prevent background holdouts from receiving shadows
  • XPU: Support for shadow linking of up to four geometry subsets
  • XPU: Ability to blend up to 16 MtIX Standard Surfaces
  • XPU: Support for string primvars
  • XPU: Multi-importance sampling (MIS) compensation for noise reduction
  • XPU: Ability to select specific Intel Embree and NVIDIA OptiX devices
  • XPU: Initial support for Gaussian Splats, with lots more to come
General UI | UX
  • Stencil map support for fast polygon visibility control via ST coords
  • Accurate (deformer-friendly) tangent space displacement
  • Dicing enhancements to improve rendering of large displacement
  • Split KineFX scene graph for world-space vs. rig-space
  • Faster and fully redesigned node info in all supported OP contexts
  • Redesigned multi-parm UI/UX to allow interactive reordering and more
  • More consistent look and feel of guides and handles in all Houdini contexts
  • Recipe Builder subnet to preserve recipe content and capture settings in .hip
  • “Forever” playback mode to advance playbar indefinitely
  • “Live Simulation” mode to run simulations continuously regardless of playbar
  • Non-contiguous character matching in text editor autocomplete
  • Ctrl-clicking Reset Simulation to also clear the simulation cache
  • Flexible framework for binding hotkeys to actions
  • Support for binding key sequences to hotkey actions
  • Volatile hotkey symbols to toggle display options
PDG & TOP Task Management
  • ML Train Style Transfer to train data using two classes of images
  • ML Train OIDN node for training an OIDN denoising filter model
  • PDG Training Monitor panel for ML training visualization
  • Convenient one-node wrapper for GLTF ROP and ROP Fetch
  • Simplified file set preparation with Preflight node
  • Ability to import work items from an externally-defined TOP network
  • Ability to run python script defined in an external .py file
  • Enhancements to python scripting when cooking out of process
  • Attribute String Edit to modify string attributes based on defined filters
  • Attribute Classify to examine work items based on unique values
  • Easy importing of key/value attribute pairs into a dictionary
  • Partition by Frame option to filter input work items by their frame value
  • ProRes codec encoding on macOS with FFmpeg Encode Video
  • Ability to control root job verbosity with HQueue, Deadline and Tractor
  • Deadline Scheduler restored to scheduling work items as tasks by default
Houdini Engine | Plugins | Platforms
  • Houdini Asset Editor for Unreal
  • Unreal PCG integration with ability to use HDAs in PCG graphs
  • Unreal plugin performance optimizations
  • HEngine plugin support for UE 5.5–5.6, Maya & 3ds Max 2026, Unity 6.0–6.1
  • HEngine API: faster data transfer via optimized shared memory side channel
  • HEngine API: Python bindings using Nanobind
  • HEngine API: support for Copernicus
  • Unity plugin optimizations and UX improvements
  • Output Log and HDA panel in 3ds Max
  • Quality of life improvements to the 3ds Max plugin
  • HQueue option to control client permissions on job output files
  • Pattern matching in HQueue ROP and TOP nodes for client parameters
  • Easier HQueue ROP job command customization using XML-based format
  • Port to x86_64-v3 feature level for additional compile-time optimizations
  • Greatly reduced startup time on certain Windows systems
  • Greatly reduced filesystem activity when loading Houdini
  • Upgraded A/V encoders and decoders
  • Adherence to VFX Reference Platform CY2025
  • Qt 6.5 default and 5.15 separate download
  • Python 3.11 only
SideFX Labs
  • Dryad Project: advanced biome toolset now in beta
  • Built-in presets and test geometries for common tree and bush types
  • Intuitive and interactive viewport diagrams to help define biomes and plants
  • Enhanced climate-based vegetation growth with dual-layer collision resolution
  • Faster biome region processing from images, curves and height fields
  • Artist-friendly biome workflows with improved visualization and speed
  • Biome toolset integration with Solaris for Karma rendering
  • Biome setup recipe for easy quickstart
  • ZibraVDB integration for VDB compression, decompression, and game export
  • 2D shape generator with intuitive viewport handles
  • Hexagon grid generator for gamedev
  • Curve and vector attribute visualization
  • Updated 3rd party integrations: AliceVision, RizomUV, Exoside
  • Updated point cloud exporter and Unreal plugin designed to work with PCG
  • Easy round-tripping of splines with labelled data between Houdini and Unreal
  • Updated Unreal plugin with artist-friendly interface for VAT importing
  • Computer Vision toolset for labelling & rendering synthetic data for ML training
  • Perforce integration as an optional install
Vulkan Viewport
  • Production-ready with full OpenGL parity and more
  • Ray-traced ambient occlusion, geometry and area lights with denoising
  • Fast headlight modes: dome, three-point, physical sky
  • Instanced USD lights
  • OpenPBR shader support
Copernicus
  • Launch in Resource Gallery via Live Graphics (COP)
  • Import external images into the Resource Gallery
  • Render engine support for Resource Gallery
  • Enhanced volumetric controls in Resource Gallery
  • Image-based region growing support in COPs
  • Indexed layout from materials using attribute mapping
  • Production-ready for all uses except advanced compositing
  • Post image filtering and advanced slap-comp exposed in Solaris
  • Fast ray-traced geometry texture baker — see also Karma
  • Live USD rendering directly into COPs
  • Real-time capturing and processing of live video
  • Versatile 3D curve rasterization
  • VDB volume rasterization and integration along camera rays
  • Advanced noise types e.g. Chladni, Phasor, Bubble, Cloud 3D, Crystal
  • Enhancements to Worley Noise(3D) and Fractal Noise(3D)
  • Grunge patterns available in future production build
  • Tiled mosaics and Escher-style pattern generation with hyperbolic functions
  • Rich set of 2D operations e.g. Color Correct, Sharpen, Defocus, Wipe, ToneMap
  • Image deformation nodes e.g. Lattice, Bend, Corner Pin, Swirl
  • Layer sampling at quantized position for pixelation effect
  • 2D tiling support
  • Convolve 3x3 filter for edge detection, blurring, sharpening and more
  • Curvature computation for edge detection, similar to Derivative COP
  • Powerful and versatile shape scattering/stamping on curves and grids
  • Heat distortion and lens distortion nodes
  • Ability to generate mask from curves
  • Curve 3D node that operates both in 2D and 3D space
  • Conversion of depth layers to and from depth, distance and height space
  • Vector Transform 2D node to treat a layer’s UV values as XY location in space
  • Triplanar UV node to generate UV coordinates for XYZ projections
  • Triplanar hex-tiling to produce seamless textures over large image areas
  • Dedicated nodes to convert VDB volumes to image layers and back
  • Support for VDB inputs and outputs of float, integer and vector type
  • Position sampling to easily extract VDB slices or create image projections
  • Fetch node to bring the outputs of a remote COP into the current network
  • Powerful invoke capabilities via Invoke Geometry and SOP Invoke(Graph)
  • Ability to run python snippet on layers and geometry
  • Geometry spreadsheet support
  • Improved height field importing
  • Enhanced visualization of height layers
  • Shadow approximation based on any given height field
  • COP nodes as camera sources in SOPs
  • Support for the “3D Output” flag on all nodes
  • Convenient “Default Settings” window for COP-related settings
  • Ability to braid multiple layers into one “cable” for more efficient wiring
  • Full support for interactive handles and states in both COPs & SOPs
  • Ability to bind 2D and 3D handles to COP nodes
  • Improved performance for EXR files and faster OCIO conversion
  • Optimized OpenCL attribute transfers in compiled COP networks
  • Faster interoperability with Texture Mask Paint SOP
  • Procedural in-memory image caching for faster playback
  • Fixed point storage for layers that do not require higher precision
  • More comprehensive handling of UDIMs
  • Feedback looping simulation support via Block End COP
  • Live Simulation option for fast and unconstrained editing of sim behaviour
  • Reaction-Diffusion solver for biology and chemistry-inspired patterns
  • Native 2D “Flow” solver for real-time fluid simulations
  • New 3D sparse pyro solver for real-time fire and smoke, native to Copernicus and accessible elsewhere in Houdini
Edited by animatrix_ - Aug. 5, 2025 03:37:05
Big if true! Huge if factual! Enormous if axiomatic!
Edited by raincole - Aug. 4, 2025 22:01:27
If I'm not mistaken, there wasn't also MoltenVK support for MacOS?
- David
Karma updates feel minimal.
Amazing release! Thank you all the SideFX team and beta testers and all the people who send proper RFEs.
Hats off and deep respect!
(btw there is even more, for example the Solaris section, and Neural Point Surfacing, it gets hidden under the Siggraph logo)
dyts
Nothing as far as I could read...
no XPU either, but that was a long shot anyway
I've watched it
chf
dyts
Capture d’écran 2025-08-05 à 09.49.39.png (728.7 KB)
- David
dyts
I've watched it
chf
dyts
I eat my words
thanks for pointing that out!
chf
dyts
I've watched it
chf
dyts
I eat my words
finally I'll be able to use Copernicus on my Mac Studio Ultra M2 ❤️
I was hoping for xpu for apple silicon a lot. Is there still any chance or we know for sure 21 won’t support it?
Release day when tho
No Karma RT this time, guess it comes with 21.5 then...
Apart from that, a breath taking release, as always - congrats to the team!!
Looks like another fantastic release…
Good to see more investment in RT sim and painting improvements.
Was hoping for 3d tracker in COPS, but hopefully in the future.
Gaussian splats - yes! Amazing updates to MPM and animation and COPS. Oh and Otis looks pretty darn exciting.
Finally quad remesher done, only took 2-3 years? :-)
Edited by LukeP - Aug. 5, 2025 13:20:39
what about solaris update?
Guys, watch the video on Vimeo and all the text is clearly legible, even when the overlay comes up. Pro tip: Shift+left/right arrow will go frame-by-frame.
Edited by eikonoklastes - Aug. 6, 2025 02:47:09
Another banger release, gratz to sideFX team.
I'm just confused by this : New 3D sparse pyro solver for real-time fire and smoke, native to Copernicus.
How copernicus is linked to a 3d pyro sim, i have no idea. Any advantage to be in cop?
Edited by bdav - Aug. 6, 2025 06:31:29
bdav
Copernicus is a GPU powered real-time image framework, so to me, it makes sense that they incorporate real-time VFX into it, I mean, real-time compositing with real-time VFX sounds pretty good !!!
eikonoklastes
You can also download the video with Vimeo, including the original file (3.41GB), I did, then compressed it with Handbrake, I now have a 705MB video that is spotless, you can really tell the difference !!!
Edited by GCharb - Aug. 6, 2025 08:37:30
That's why I switched to Houdini.. such an amazing updates and new features.
Love the MPM updates.
Thank you Houdini Team !!
"Simultaneous, fully coupled muscle and tissue simulation"
Awesome, I wonder if this makes two characters interacting with each other potentially more manageable, e.g. one character punching another while tissue sim is running on both?
