UV Layout: Pin some shells and layout the rest around those?
   326   2   0
Hi!
I have 2 geos I'm combining together. The Green are UVs I want to keep intact, the pink UVs are the ones I need to layout inside all the available spaces. I tried a bunch of settings in the UV Layout sop but it never works.
Any ideas?
-Olivier
Edited by olivierth - Aug. 24, 2025 13:02:46
...The best I could find is the setting Pack into: Islands From Second Input. It does exactly the opposite of what I want. I packs INSIDE instead of OUTSIDE.
I could create a geo that would be the opposite (with booleans) and pack into that but I'd like a faster method since I'll be doing this on thousands of shapes and layouts.
Make a group for your pink geo. Set the UV Layout to only run over that group (so the green geo isn't modified). Select the option: "Avoid Packing Over Non-Group Islands".
