I imported an Alembic file from Blender. Now I want to edit the camera animation. But I don't find any curves to edit.
Anyone can help?
GZ
Alambic import : edit camera animation
1072 4 1-
- Grendizer
- 392 posts
- freshbaked
- 154 posts
- Grendizer
- 392 posts
Thanks a lot. I chose FBX, but before exporting, I had to do the following :
For export purposes, consider that the camera currently in Blender, doesn’t really have keyframes; it has a constraint whose origin comes from the markers. But in Houdini (or another 3D app), we want to recover the camera animation in order to get animation curves that we can correct. So we do the following:
* Select the camera and rename it to "CameraTracked".
* Duplicate the camera using **CTRL+C then CTRL+V**.
* This creates a new collection—rename it to **TrackingSetup_Cns2Curve**, and rename the child camera inside it to "CameraCns2Curve".
* With this new camera, go to the Outliner, expand the camera, then expand "constraints", select "camera solver", and in the properties panel below, click the button "Constraint to F-Curve".
* Open the Graph Editor to visualize the animation curves for position and rotation on XYZ axes.
* These curves can be corrected either in Blender or in the 3D application to which the scene will be exported.
then export to FBX
then export to FBX
Edited by Grendizer - Sept. 20, 2025 09:35:19
Houdini gamboler
- tamte
- 9710 posts
if you have to bake it in Blender anyway just to be able to export as fbx with curves, then it may be easier for you to use Bake Animation ROP to bake animation curves from Alembic camera to a new camera in Houdini, which will save you those manual steps
Edited by tamte - Sept. 20, 2025 12:45:51
- Grendizer
- 392 posts
