houdini 21,In the viewport, Transparency overlap error
   1598   7   1
houdini 21,In the viewport, there is an issue with overlapping parts of multiple objects with alpha attributes from the camera's perspective.
In many cases, we need to provide customers with correct animation rehearsals that include transparency relationships. However, in Houdini 21, there is an error in the display of transparency. Can this issue be fixed?
By default, the Houdini viewer only displays the frontmost transparent surface for performance reasons. You can get up to 8 layers if you change the Transparency Quality to High (Material tab of the display options).
maleeander
I followed the steps you mentioned, but it didn't work
This appears to be a bug in the software
Sorry, Medium and High quality transparency is only available in Scene Light mode if you have lights in the scene (or if you turn on Ambient Occlusion). Only Low quality is available in Work Light mode. It's not ideal, and hopefully something we can address in the future.
I chose the scene light mode, but it still doesn't work
You also have to actually have a scene light for it to work I believe.
Liesbeth Levick
Technical Director: CFX
