From typing “hscript myfile.hip” it churns out “Unknow Command: Imgview” and a couple of variations over and over. I opened up the .hip in a texteditor and most of the file are these Imgview commands and they look like they are repeating the same variables over and over. I removed any misc ops from COPS in the off chance. The scene seems to load after that though. I'm using hscript 5.5.36
Cheers
Henster
hscript error - "Unknown command: Imgview"
5823 6 0-
- Henster
- 196 posts
- stevenong
- 1634 posts
- Henster
- 196 posts
The hip file is the same version as houdini. I was wondering, are cops supported by hscript? There is a flag “-u” to turn on the ultimatte cop in the docs. I don't suppose theres another flag that turns on the whole of cops is there?
I noticed there was another program as well as hscript called hrender which is purely for rendering composites. I've got a bad feeling that when you run the gui version it interfaces the two together.(except its got no .exe extenion, prehaps not able to run independently on nt) hmmm..
has anyone else tried rendering a cop network throught hscript on NT?
Thanks for all replys
Cheers
Henster
I noticed there was another program as well as hscript called hrender which is purely for rendering composites. I've got a bad feeling that when you run the gui version it interfaces the two together.(except its got no .exe extenion, prehaps not able to run independently on nt) hmmm..has anyone else tried rendering a cop network throught hscript on NT?
Cheers
Henster
Henster
- stevenong
- 1634 posts
- Henster
- 196 posts
- stevenong
- 1634 posts
- Henster
- 196 posts
Up until today I thought the majority of my crashes where caused by dense geometry intersecting itself. I'm not quite sure where I got this idea?
I use the pic() function a couple of times to get data out of a copnet. Today I removed these and the crashes stopped straight away.
Frequently if I try to switch from sops,rops,chops etc to cops I get a fatal error, sometimes it throws a segementation error in there as well. Segmentation errors I think are caused by trying to address memory that does not exist so I left it. Is this not normal?
Thanks for the help
Henster
p.s. 5.0.305 hasn't solved this one sadly
Thanks for the help
Henster
Henster
