CHOPS and Game Pad help.
   707   1   0
I'm trying to use the gamepad function to fly a realtime plane around the 3d viewport of houdini.
I got transform out of the shelf tool gampad camera function. works great. can copy it to any geo and fly it around the viewport in realtime without have to fun the timeline. very nice. But I am running into a wall when trying to remap the controller. I'd like different joystick axis and buttons to go to different function on the transform.
The setup uses a node called "device transform" to handle it in a black box kinda way, and I don't like that. I wanna map it myself. It also says don't use rotations, which is a bummer cause that's exactly what I want. I wanna barrel roll damnit!
Anyone know what I mean and can help me build this node possibly in a vop so i can have some flexibility and keep the TimeSlice realtime fun?
Yeah, I know exactly what you mean. The `device transform` node is convenient for quick setup, but it definitely feels too “black box” once you want custom mappings or proper rotational control. The warning about avoiding rotations is mostly because Euler rotations can get messy fast with realtime controller input, but that doesn’t mean you *can’t* do it.
If you want full flexibility, you’ll probably have a much better time bypassing `device transform` entirely and reading raw controller values yourself using the Gamepad CHOP / Device In CHOP, then exporting or processing those channels manually.
A common approach is:
* Use Gamepad CHOP to grab raw stick/button axes
* Remap ranges with Math CHOP
* Filter/smooth with Lag CHOP
* Convert to transforms manually
* Feed into a Transform SOP/Object via CHOP exports or VOP/VEX
For rotations specifically, quaternions are your friend if you want smooth barrel rolls without gimbal weirdness. Even a simple setup where:
* left stick = translate X/Z
* right stick X = yaw
* right stick Y = pitch
* shoulder buttons = roll
can feel really nice once smoothed properly.
You could absolutely build this in VOPs too, especially if you want procedural blending or custom inertia. TimeSlice should still behave fine as long as you stay mostly in CHOPs and avoid heavy cooking downstream.
Honestly, this kind of controller tweaking reminds me of solving a Letter Boxed puzzle — the built-in solution works, but the fun starts when you break apart the system yourself and find a more elegant custom path through it.
Visit this site: https://www.lettersboxdanswers.com/ [www.lettersboxdanswers.com]
Edited by hellencharless54 - May 15, 2026 09:12:30
