Houdini MCP for Codex Desktop on Windows - working setup + f
   5440   2   1
Hi everyone,
I’ve been testing Houdini MCP with Codex Desktop on Windows and put together a working setup for controlling a live Houdini session from an AI coding agent.
The setup lets Codex connect to Houdini through MCP and hrpyc, so the agent can inspect and edit the current scene: create nodes, wire networks, set parameters, run Python in the open Houdini session, and work with Solaris/USD graphs.
I also opened a pull request with a couple of fixes that were needed to make this reliable on Windows:
- keep FastMCP stdio output clean by disabling the banner
- run stdio without HTTP host/port arguments
- start Houdini’s hrpyc listener through ThreadedServer
- stop the hrpyc server via the server object instead of the missing hrpyc.stop_server API
- document a tested Codex Desktop + Houdini 21.0 Windows setup
Project page:
https://arybashov.github.io/houdini-mcp/ [arybashov.github.io]
Fork:
https://github.com/arybashov/houdini-mcp [github.com]
Upstream PR:
https://github.com/oculairmedia/houdini-mcp/pull/8 [github.com]
Telegram updates:
https://t.me/cg_pipeline_lab [t.me]
Tested with:
- Windows 11
- Houdini 21.0.671
- Codex Desktop
- Python 3.14
- RPyC 5.3.1
The most stable architecture so far is:
Codex Desktop
-> stdio MCP server running in normal Python
-> RPyC 5.x
-> Houdini hrpyc listener on 127.0.0.1:18811
I’m sharing this in case other Houdini users are experimenting with AI agents, MCP, Solaris/USD automation, or DCC pipeline tools. Feedback and testing on other Houdini versions would be very useful.
I'm getting this error when I try to start the server:
houdini_mcp_plugin\server.py:285: RuntimeWarning: coroutine 'AsyncIOBackend.run.<locals>.wrapper' was never awaited
  logger.error(f"MCP server error: {e}")
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
Any clue?
guilhermecasagrandi
https://arybashov.github.io/houdini-mcp [arybashov.github.io]
create a new project in codex, unzip codex-windows-stdio-fixes.zip in it ,let codex help you setup and find the bug
