Hi.
I have this volume created in Houdini and saved to .usd file.
I want to import it to Solaris, but I need to make some adjustments in SOPs first.
I've been struggling a whole day with no success.
What is correct approach in this kind of situation?
USD Volume import to Solaris through SOPs.
618 1 1-
- slepy8
- 1 posts
- edlgm
- 51 posts
You should be able to either:
1- Use a usd file import node and import it onto sops, making sure you unpack into Polygons.
2- If its loaded as a reference or already in your scene graph, use a sopmodify node and again unpack it to polygons so you can tweak it.
Edited by edlgm - June 15, 2026 19:05:11
Enrique De la Garza
CG Supervisor @Frame48
