Tweak skeleton by transforn handle
   548   1   1
Are there anyway to move joint in skeleton sop with transform handle like edit sop?
Thanks.
The H hotkey is suppose to show the transform handle when you're in Modify mode but I couldn't get that to work on my 21.0.631 build. If that doesn't work for you please log a bug. Otherwise, I found that I could manually enable it with the right-click menu on the Show Handle button. See image .
Edited by edward - May 28, 2026 20:17:37
