Trying to Karma-render the Pyro shelf preset 'GPU torch'
   735   2   2
Hi
I am trying to render the Pyro shelf preset 'GPU torch' through Karma/XPU. The flames in the rendered image though are just plain white, while in the viewport everything looks disco.
As far as I have understood I needed to insert a 'pyrobakevolume' after the 'pyrosolver', which I did, and assign a pyro shader in the lopnetwork, which I also did.
Are there things I need to hook up further before seeing actual flame colors?
torch render test.hiplc (2.1 MB)
I'm guessing you're rendering in XPU, so try using Karma Pyro Shader instead of Pyro Shader.
That makes a whole lot of sense.. Thanks!
