Sop camera not writable
   550   1   0
What is the reason for this prompt "Camera Parms are not writable!" ?
Thanks.
sop cam.png (1.5 MB)
likely because you are looking through camera of the Display flagged node, which doesn't have those parms
drag your camera1 node into the viewport, the path will display testgeometry_rubbertoy1/camera1:cam1 then editing through viewport will try to edit the testgeometry_rubbertoy1/camera1 node which does have those parms and should work
