H22 bug - Edit Selected hotkey not working
   958   2   2
I noticed a bug in Solaris where the Shift+Enter hotkey to "Edit Selected (Houdini/Panes/Scene Graph Tree Menu)" will only work on actual primitives in the Scene Graph, but not in the list of prim vars to the right. As an example, create any test geo, expand the primitive, click on the mesh, then in the list on the right click on, for example, subdivisionScheme and hit Shift+Enter. It will not work. If you right click it with the mouse and do it from the menu it will. The hotkey will also work if you just click on mesh_0; it will then create the appropriate editMesh LOP.
All the best
Janis
I am seeing the same issue as well.
Thanks,
Todd Manus
www.artstation.com/thenotepadshow
www.itodd.net
renderman.pixar.com/the-notepad-show
https://www.sidefx.com/forum/topic/15603/ [www.sidefx.com]
Chris McSpurren
