Can't Select Joints When Using Motion Mixer "Match Joint"
   975   2   1
I'm getting this error when I hit the button to select the joint that I want to match from the list
UnboundLocalError: cannot access local variable 'char_parm' where it is not associated with a value
I've copied the nodes from electra to configure the character for motion mixer. I've tested with that configuration running and without it.
I'm not sure how to fix this or what the root cause is. Any help is appreciated.
This is a recent regression and I'll get you a fix today. I can see that you logged a bug correctly on our bug database too.
I made the fix, please test again with 22.0.439.
