Hi!
I'm used to doing the UV layout by hand in Maya with full control of where each shell goes. Currently, in Houdini, the only way I found was to use a uvEdit node per changes. Is there a node that allows me to do all the transforms in one place?
All Manual UV layout in a single node?
360 3 0-
- olivierth
- 1287 posts
- freshbaked
- 169 posts
- olivierth
- 1287 posts
Currently, the way I use the UV edit sop, I have to click on the "Select Geometry" button to select one shell, move it. If I want to move another shell, its another selection so I end up using a second UV edit sop.
I've tried selecting the node, pressing Enter in the UV view and moving a shell. I can't find out how.
Can you give me some pointers? I have no idea how.
-Olivier
- freshbaked
- 169 posts
Sure, drop a uvedit and enter the state, in the uv view hold "S" and make your selection (double click will select full shell), release "S", do transformation, hold "S" to make new selection, rinse repeat. While holding "S" you can change the component type in the top toolbar to verts if you really need to mush stuff around.
