VEX: Compare an Array to another, check if it matches{[SOLVED]}
   164   1   0
Hi!
I have an array I need to compare to against a thousand other arrays to see if there a perfect match. I tried the find function but I think its not meant for comparing 2 arrays. I get an error.
My other solution would be to do a for-loop within another for-loop. Is there a function that does this already? I'm lazy...
Edited by olivierth - Nov. 23, 2026 16:48:42
-Olivier
Doh!
I can simply do:
if(myArray_A == myArray_B) i@FoundMatch = 1;
-Olivier
