Loading scene error msg
11471 4 1-
- haggikrey
- 45 posts
- Allegro
- 696 posts
This means that Houdini has gone through some changes since the last version of Houdini that you had installed, and that some of your nodes had to be changed to compensate.
Probably nothing to worry about, though good housekeeping would be to go in and recreate those particular nodes if you can.
Stephen Tucker
VFXTD
VFXTD
- haggikrey
- 45 posts
- JColdrick
- 4140 posts
It's related the the particular release of houdini that you saved that file with. So if you last saved it with 9.1.100 and you loaded it in 9.1.101, it's possible that something like this can happen(it's still in beta and things get tweaked). Having 9.0 on the same system is OK and won't affect this.
J.C.
J.C.
John Coldrick
- haggikrey
- 45 posts
