Hello, I'm trying to get myself familiar with all the new gadgets in H9, but I'm having a strange problem on startup.
Houdini takes about 5 minutes to startup, it appears because it is creating the icons everytime. I know this is supposed to happen on your first startup, but I can't get it to stop. Any suggestions how I could correct this?
I'm running H9.0.828 on XP and an ATI card. I installed to C:\Houdini9\
I've tried launching from different locations, by command prompt, but no luck.
I can see hsvg running on startup and the icons being made in my temp folder.
Thanks in advance,
Zane
Trouble with Icons on Startup
9757 4 0-
- zjwaldman
- 3 posts
- Joe
- 483 posts
- zjwaldman
- 3 posts
Hello again,
I deleted the houdini 9.0 folder in My Documents, and started up houdini and then tried again. I'm afraid with the same results. If it helps, the error message from the console window is:
libpng error: Not a PNG file
I'm wondering if it could have anything to do with me needing to set up some environment variables?
- Joe
- 483 posts
- zjwaldman
- 3 posts
