Cannot connect to license server - Ubuntu
   17691   6   3
I just downloaded Houdini Apprentice for windows a little while ago, it installed successfully and worked great. I prefer to work on linux (cause its better) but I am unable to “connect to license server”. I tried editing the location of the server but still get the same error. Any suggestions?
hi - is the license server running? maybe not by default - try:
/etc/init.d/sesinetd start (run as root or with sudo)
i don't have “sesinetd start” in /ect/init.d/
any other solutions?
Perhaps you haven't installed the license server. Run the install again and keep everything defaulted.
Then of course you need to “source houdini-setup-bash”
“everything is coincident”
Hey i got the same issue..
i installed houdini before but what i did was run the houdini install as root or something.
you have to set a command before executing the install.
only i forgot what that command was.
i'm tryng it again now and don't know the command so maby someone here can help a lending hand.
got it:
1.go terminal
2.go to houdini.install directory
3. type sudo ,/houdini.install
for password type your normal password.
Hi guys,
How do you get the license server to run automatically and not start it each time?
I'm using Ubuntu 7.10
