node names in network editor
   4415   5   0
Hello
Is it possible to change the color of the names in the network editor?
thanks,
bern
yeah…there are some config files where you can do this…
I'd try to avoid it if possible…
what are you trying to do?
Training Lead
www.sidefx.com
I loaded some example file from Odforce.
http://forums.odforce.net/index.php?showtopic=6708&st=12&p=44883&#entry44883 [forums.odforce.net]
In this file there are some blue node names…
thanks arctor,
bern
pt_instance.hip (193.5 KB)
the blue node names mean that the node is an instance of a digital asset…or that it has a comment
Training Lead
www.sidefx.com
Hello arctor,
how can I add a comment for a node ?
thanks,
bern
RMB on the node and select “Edit Comment”
to read the comment MMB on the node
comments will be a dark blue
nodes that are HDAs will be a lighter blue
red is an HDA node that has been unlocked…
there is a list somewhere but I can't find it…
Training Lead
www.sidefx.com
