when I use the back und forward buttons to navigate in panes, some panes switch their status too even if they are not linked together. That really is annoying. Is it just me?
Bug in jump back/forward in panes
8150 4 1-
- Buhrmi
- 15 posts
- EigenAlex
- 639 posts
- old_school
- 2540 posts
If you want to totally disassociate a pane from all others, you need to do two things:
- change the number to another association or none in the upper right corner.
- In the Pane menu > Linking > “Tie To Parent Network's Current Node” should be off.
It is the second option that turns on and off the behaviour where two panes follow each other around. e.g.: one in Objects and the other pane set to follow will display the SOP network.
- EigenAlex
- 639 posts
- old_school
- 2540 posts
