cant install still! hkey.exe has generated errors
   6628   2   1
I would like to learn houdini so I installed the newest version 6 so I can learn at 3d buzz. I have no other trouble with other 3d software but when I try to enter a license I get hkey.exe has generated errors and will be closed….
Here is the license server info.
Please advise and thank you.
Generated on: Mon May 19 15:35:33 2003
Local host name: OEM-JEH175DFZ5X
Local server code: 27a2af83
Local ip address: 127.0.0.1
License server name: oem-jeh175dfz5x
License server server code: 27a2af83
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: No
License server version: 6.0.286
May modify server from this machine: Yes
License Administrator version: 6.0.286
Http proxy host: (none)
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER oem-jeh175dfz5x ——–
*** WARNING *** - No valid server lines found
hserver -l output:
Hostname: OEM-JEH175DFZ5X
Uptime: 0:57:01
License Server: oem-jeh175dfz5x
Server Version: sesinetd6.0.286
Version: Houdini6.0.286
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
772 of 1023 Mb available
CPU Usage: 68% load
0 active tasks (1 slots)
* Could not open the licenses file. *
Thank-you for the license output. It shows that everything is fine except that you don't have a licenses file or you do have one that is bad.
Are you root when you try to install the licenses? Perhpas try using hkey as root.
Go to /usr/lib/sesi and cat < licenses and see what is in the licenses file. Are there any license strings in there?
You can build the licenses manually by going to license.sidefx.com and reading the apprentice instructions. You will have to either use command line tools or edit the file directly cutting and pasting in the license strings very very carefully.
Most of the time, when hkey crashes with the message “hkey.exe has generated errors.” it's because of video card problems. Do you have the latest video drivers installed?
