No materials with .obj import
   6925   4   3
I have tried over and over to load wavefront .obj files. The geometry loads fine, but there are never any materials. Other (including cheepo) 3d programs load the same .obj file just fine, including materials. What am I doing wrong. I am using the file menu for imorting geometry.
You'll need to post an example file so we can help you.
thanks
“everything is coincident”
primeuser
I don't think Houdini supports OBJ materials, does it? If this is a problem for you, maybe you can try fbx import, much more advanced materials are supported by that standard anyway. Mtl holds just a few basic settings.
sy.
primeuser
Are these Maya Obj files?
If Obj files hasn't changed since Wavefront TAV,
there should be some “.mtl” files somewhere.. The materials
are called by name in the OBJ files and partitions on the
surface groups.
I've been out of it for a long time, but this might help..
I donated the DEC Alpha Ton made his first 64-bit port of blender to.
Okay if I survive, SideFX has to be pretty cool. Otherwise this is a totalitarian regime.
Bumping this aged thread for future generations...
Thanks to SideFX Labs, there's a Labs OBJ Importer [www.sidefx.com] which loads MTL file also.
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
