hepl!!:render sequence with renderman11 in houdini 6 problem
   4857   2   1
when I render sequence with renderman11 in houdini 6, it shut down my computer in few frames rendered!!!! why???have any of you suffered this problem???
^_^
Check external factors first. CPU temp? BIOS version? Does rman work otherwise? Are you using IT or the framebuffer?
Henster
Henster
I can use the renderman 11 render sequence in maya use Mtor perfectly.
it seems that its the houdini's problem……I saved the pictures in tiff file.
did you try it???
^_^
