I try to install HOUDINI9.1.273 to my laptop but giving problem,
after the lisecence admin. window nothing happining ….
OS win vista(32)
and I'm using wire less internet.
any one can have solution for this problem?
6340 4 0-
- jiththan
- 4 posts
- circusmonkey
- 2624 posts
- jiththan
- 4 posts
Hi circusmonkey!
I finished installation without any problem, when I run Houdini 1st popup window: shows non-commercial license I have selected that, and then communicate with End User Licence Administrator after that nothing happened. I did command line licensing it doesn’t work
“sesictrl 6815a8df a7215c7b46cda1adc02ddb0de90bcc3e6ee71dda505c32”
I have installed following versions same thing happened:
houdini-9.1.277-win32-vc8,
houdini-9.1.244-win32-vc8 and
houdini-9.5.140-win32.
I use wireless internet connection. May be I’ve
Different proxy settings so how can I solve this matter?
OS – WIN VISTA HOME PREMIUM
GRAPHIC CARD –MOBIL INTEL 965 EXPRESS chipset family
Please send a solution for this problem I am new to HOUDINI and eager to Learn.
Thank you very much for your support.
RGDS
jiththan
RGDS
jiththan
3dmanithan
- circusmonkey
- 2624 posts
Just the very fact your using on board based graphics card screams problems do a search on this site and you will see all the issues.
You can try If you're on Windows and set the environment variable HOUDINI_OGL_SOFTWARE to 1 first, then Houdini should run, albeit slowly. Really at the end of the day trying to run any 3d application using on board graphics is doomed
R
R
Gone fishing
- jiththan
- 4 posts
