I need to use the group SOP in order to have a point selection grow, following the edge connections. its works fine when you define a single point with the parameter Point Number ( /point ), but I need it to work from multiple points. It si said in the doc that the blossoming effect can occur from multiple points if they are already selected ( like in the pattern field I guess ). In this case, the point number field is disactivated, but the blossoming still occurs from only a single point. I cannot make it work from more than one. I guess I am doing something wrong, but I have no idea what…
