Problems with network editor
   4491   2   1
I'm having an issue with the network editor in that when i template a node into a copy node, houdini does not show the dotted line to confirm the input. When i click view imput source it will highlight the template, and the copy node will work, but it's quite frustrating having to work half blind.
Does anyone know a way to turn the dotted lines on or is this likely to be a bug. I have re-installed houdini and also upgraged to the latest build of appretice but it still doesn't want to work. Any suggestions?
This sounds like it might be a driver bug. Do you see other dotted lines in Houdini? For example, when box selecting in the worksheet?
Yeah i do, never had any problems with the other editors/viewers.
