In VOP builder, I made a Surface shader.
In it, placed a skin node, wired color to Cf,
Then placed a parameter.
Tried to use it in SHOP. Good.
Enter Command Line Tool,
I enter the folder where the .vfl file exist,
vcc -u VEX_Skin.vfl
then copy the VEX_Skin.vfl and VEX_Skin.vex to $HOME/houdini/vex/Sop
copy the VEX_Skin.ds to $HOME/houdini/vex/Dialogs/Sop
Edit VEXsop file in $HOME\houdini\vex by adding the line:
VEX_Skin vex/Dialogs/Sop/VEX_Skin.ds -inputs 2 -label “VEX Skin”
Restart Houdini, in SHOP, TAB, no such item.
Why?
Thank you.
The version is 5.5.230.
How to compile the .vfl file
5970 3 0-
- Xiangbiao
- 27 posts
- Xiangbiao
- 27 posts
- mtucker
- 4558 posts
This is because you put the entry in the vex/VEXsop file. This file is where you list all VEX based SOPs. If it is a surface shader you wrote, remove the entry from the vex/VEXsop file, and put it in shop/SHOPsurface. Then it should appear as a SHOP. I'm a little confused by the “-inputs 2” you put in the index file, because SHOPs do not have inputs. I would suggest getting rid of that when you move to the SHOPsurface file.
Mark
Mark
- Xiangbiao
- 27 posts
