Hello
I'm using Houdini 6 Apprentice Edition, and when I try to create reflections off of a planar surface, the reflections are only appearing in a circular area on the surface, even though the entire surface is illuminated by one light, and the object only has one shader applied to it.
In addition, the reflections seen in the circular area appear distorted, like in a fisheye lens. I appreciate any help I can get. Thanks!
phoenix1606
Reflection Issue
11433 12 1-
- phoenix1606
- 18 posts
- Mario Marengo
- 941 posts
Are these reflections traced, or mapped?
What shader is being applied? One you wrote? Or one of the shipped ones?
And why do you mention the light? Is this a Light shader?
If it's a mapped reflection, then everything depends on how the reflection vector gets calculated… but then, for a flat surface, that gives you a single lookup direction (one color)…
Need more details…
Need more details…
- phoenix1606
- 18 posts
I created my own shader in VOPs by wiring the Color output from a woodPlank shader into the diff input of a Blinn lighting model, which is wired out to the Surface Color (Cf) input of the Output VOP.
There are no lighting shaders, so I guess the lighting is irrelevant. I hope this is enough information…
phoenix1606
phoenix1606
- wolfwood
- 4325 posts
The default woodplank VOP already has a lighting model (VEX Specular)built into it so you don't need to connect it to a another lighting model. Just connect the woodplank's color to Cf.
If you want to change it to Blinn then select the woodplank VOP and hit enter. This will take you inside the woodPlank network. Go to the “lighting1” VOP and change the Lighting model from VEX Specular to Blinn.
This might fix your problem.
jim.
jim.
- phoenix1606
- 18 posts
- wolfwood
- 4325 posts
- Mario Marengo
- 941 posts
- phoenix1606
- 18 posts
- wolfwood
- 4325 posts
- phoenix1606
- 18 posts
here's the file…I hope this helps.
http://www.illusionmedia.net/houdini6RoomRebuilt2.hipnc [illusionmedia.net]
phoenix1606
phoenix1606
- wolfwood
- 4325 posts
- wolfwood
- 4325 posts
To see what was happening enter your “Floor” SOP network and append a Point SOP to box1. Set it to “Add Normals”. Turn on display normals to view the normals. Turn on “consolidate points” and you will see the normals being averaged over 3 directions. During the render those corner normals were being smoothly interpolated across the surface causing the funny reflection. With “consolidate points” off the normals at the corners point in the correct direction and during rendering are correct.
Alternatively you could have left on “Consolidate Points” and in your VOP networked created a Inline VOP. For your code you would put something like.
$Nn = computenormal(P);
Then connect Nn to the N input of woodplanks. This will cause a normal to be computed using the derivatives at the current point being shaded which ignores the normals at the corners.
I hope this helps.
jim.
I hope this helps.
jim.
- phoenix1606
- 18 posts
