How to reduce poly count according camera distance?
   12036   6   3
Hi everyone
I created one tours and grid the copy node replace to grid point on tours now I want reduce poly count according camera or any object distance .
Near tours I need more polycount far tours less poly count.
Edited by - Nov. 26, 2008 10:53:06
I think you want to put your PolyReduce SOP after your Copy SOP. Then in your PolyReduce SOP, use the Distance option and for the Object parameter give it the path to your camera.
BTW, please try to reduce the size of your posted images to less than 800 pixels in width.
edward
If I add poly reduce after the copy node it's reducing overall but I want to reduce tours by tours .
try the foreach sop
One of possible setups:
reduce_by_distance.hipnc (84.8 KB)
Very nice Sy. Only one issue with it is the reduction is reversed if the camera happens to be in a negative quadrant (effectively)
tallkien
Is it? Oh, I'm embarrassed ops: Well, here is a first thing comes to my mind, although I'm sure we're already on a wrong path (too complicated). I just switch min/max values based on camera position.
reduce_by_distance2.hipnc (118.9 KB)
