Deforming eye a la pixar?
   15633   12   6
I was looking at a document on pixar research web site…the document on harmonic coordinates for character animation.
http://graphics.pixar.com/library/HarmonicCoordinatesB/paper.pdf [graphics.pixar.com]
On page 6 there's an exemple of a deforming eye, but the pupil and iris of the eye stay round all the time.
I was actually wondering if anybody's knows a way to actually get the same effect within houdini by any means possibles…to have a deforming eye with the pupil/iris keeping a round shape, while the white part is streched.
or do you absolutely need harmonic coordinates to get that kind of effect?
Anyone? Thanks!
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
you could potentially model the iris and pupil as separate geometry, but I'm not one for character rigging…
Stephen Tucker
VFXTD
how about projecting the iris texture after the eye has been deformed disregarding the previous uvs
Hi
I made a small test based on projection as SpOOkyPaul said
you can add any deformation/rotation/scale and it works, just a simple example for characters that have textured eyes.
_mix_cartoonyEye.avi (369.0 KB)
eye.tif (44.7 KB)
_mix_CARTOONY_EYE_v02.hipnc (374.5 KB)
varomix - Founder | Educator @ Mix Training
Technical Artist @ Meta Reality Labs
Just remember that this projection will cook per frame. It is great for rendering as it gives you lots of control but you may want to rig a preview differently for viewport speed.
-k
(Note: I haven't looked at the file.. but if it is what I think it is.. then it will cook, no way around that)
Also you could cache the cooking
thanks varomix!
simple but efficient, it could actually drive a displacement map to fake a modeled eye…nice!
Anybody with a solution using a “highres” modeled eye?
JR Gauthier
www.turboatomic.com
I'll try to do that later and share the file
You're da man!!
JR Gauthier
www.turboatomic.com
Okey I had some time off
This is how I made it, I think this could be made better with blendshapes
or even better if you mix this with blendshapes.
hope this helps someone, it might need some clean up, sorry :wink:
realisticEye_deliver.zip (343.2 KB)
mix_realistic_eye.v01.avi (245.0 KB)
Sweet, I'm trying it right away!!
thanks varomix!
JR Gauthier
www.turboatomic.com
other way i can think about it is to use Nurbs,
set the eyes as a sphere, and the iris nurb and Bolean them,
in maya, I'd deform the eye with a lattice, and hook that up *-1 to the iris, giving it the opposite deformation, thus cancelling it out.
