[Q]: How to create "recursive" geometry ??
   4706   5   1
Hi !
I want to create some geometry, that is recursive.
But I am stuck.
something in the lines of
func (x,y,z,size,level,Obj)
for i=0 to 2
for j=0 to 2
for k=0 to 2
if (i!=1) or (j!=1) or (k!=1) then
if level>0 then
func (x+i*size,y+j*size,z+k*size,size/3,level-1,Obj)
else Obj(x+i*size,y+j*size,z+k*size,size)
next k
next j
next i
removeDoublePoints()
removeDoubleEdges()
removeDoubleFaces()
SetPivot()
endfunc
Using Geometry nodes should be inappropriate, because I guess, I am not allowed to feedback a nodes output…
What did I miss… ??
TIA !
If you can't script/program it, it's no good at all !
There is a Feedback SOP in the protoinstall.
Wolfwood
THX Wolfwood,
but you're just confuzing me. I'm still confuzed. Only “Feedback” node found so far is a CHOP… (me still noob!!) and the 9.5 online help did not show anything related to protoinstall.
I thought I could use some Hscript/Python, to implement that function.
Thanks for your suggestion anyway!
Edited by - Jan. 5, 2009 15:37:38
Offhand, I don't think there should be any issues in creating a Python SOP for recursion if you want to go that route.
Also, look at the ForEach SOP
but you're just confuzing me. I'm still confuzed. Only “Feednack” node found so far is a CHOP… (me still noob!!) and the 9.5 online help did not show anything related to protoinstall.
You need to run the command line tool, proto_install. Select Windows->Shell from the main menu. Then do:
source $H/houdini_setup
proto_install
SOP_Feedback.inst should be somewhere in the list; enter the number & select “2) Install in …/houdini9.7”. Restart Houdini, and it should appear in the SOP list.
Proto-installed OPs are operators that are not yet tested for full production use, so use them with care.
