Deleting scattered points
   6443   2   1
I am very new to houdini and I am trying to scatter a few things on a grid based on some predefined parameters.
I have used a scatter sop to spread out the points. I want to choose all those points that are closer than a particular distance and delete them. Is there any way to do this?
Thanks in advance for your repliesfor your replies
Read this thread on your options
http://forums.odforce.net/index.php?showtopic=6665&hl=delete+points+based++distance [forums.odforce.net]
rob
Gone fishing
I did a little setup, I hope it can help…
I use a sort sop after the scatter to reorder point number based on distance from a point. I referenced a null to this point coordinates so it can be animated. Next, I put a delete sop to delete every point that is numbered beyond a arbitrary number. I created a slider to make this easy to animate…
Press play when you open the scene you'll see a bit what it can do. Right now it keep the point beyond a certain radius around the null, put it good easily do the oposite and delete all the point that are close to it…
Is this what you anted to achieve?
cheers!
delete_distance_from_point.hipnc (45.6 KB)
JR Gauthier
Character Animation & Design
www.turboatomic.com
http://www.vimeo.com/user2847970 [vimeo.com]
