hello
I have a big problem to use houdini.
I use Apprentice 6.0.286 (hfs-6.0.286-linux7.tar.gz) and the installation is good.
As described in the file installation, I initialize the variables environment.
But when I launch hkey to obtain a non commercial licence. The shell say
$ source houdini_setup
The Houdini 6.0.286 environment has been initialized.
$ hkey
hkey relocation error /usr/hfs6/dsolib/libHoudiniUT.so symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
$ houdini
houdini command not found
Frankly, I doesn't understand very well what that wants to say.
On the forum, it is written that houdini doesn't work if my computer is not connected on a network. It is right?
I have a network card but I do not have a network at home. And to obtain a licence, I use my modem.
All that is complicated (I do not have a problem under Windows)
can you help me? thank you!
Redhat 9, kernel 2.4.20-9 with kde 3.1-10
Amd Athlon 1.3 Ghtz, 512 Mo Ram, Geforce 2 mx with the most recent drivers.
newbie question: houdini on redhat 9
3724 1 0-
- bioubiou
- 1 posts
- JColdrick
- 4140 posts
The Redhat 9 issue is discussed here:
http://www.sidefx.com/forum/viewtopic.php?t=1195 [sidefx.com]
Essentially you need to add:
setenv LD_ASSUME_KERNEL 2.4.1
to your environment.
As far as the network issue, I believe it's all about the network card - Houdini uses the MACADDR of a network card in order to run licensing. You'll need to have one installed.
J.C.
J.C.
John Coldrick
