I made this geometry (cubes copied to sphere points).
When I export as OBJ and import this OBJ file in Maya I get one object.
I can not select the different cubes in Maya.
How can I get different objects in Maya , that I can select individualy..?
thanks,
bern
geometry from Houdini to Maya
7914 9 3-
- Bernard
- 523 posts
- keyframe
- 1533 posts
- Bernard
- 523 posts
- jesta
- 311 posts
- Allegro
- 696 posts
- oleg
- 350 posts
- Bernard
- 523 posts
- oleg
- 350 posts
If you mean the pivot of each object, then simply select all the objects and choose Modify->Center Pivot from the main menu.
If, on the other hand, you want the transform attributes of each box to be at its center, then I'm not really sure how do it short of using MEL (but then again, I'm a bit more of a Houdini user rather than a Maya user, so there may be a simple way that I'm missing
Oleg Samus
Software Developer
Side Effects Software Inc.
Software Developer
- Bernard
- 523 posts
- JColdrick
- 4140 posts
