DOP bug
   4419   4   0
Using H 10.0.249.3 , windows xp 32
Create a grid and make it a cloth object.
Then create a sphere and make it a static rigid body.
Transform the sphere a bit lower (y)
The cloth object must normally fall on the sphere but it doesn't.
If you do the same procedure but change the sphere in a torus object then the system works…
thanks,
bern
Change your sphere from a primitive to a polygon. Cloth objects need to be poly with H10.
J.C.
Edited by - April 24, 2009 16:45:53
John Coldrick
Are you using a Primitive Sphere? If you are, please try a Polygon sphere.
Cloth uses the points on the geometry to calculate collisions now.
Cheers!
steven
Thanks Steven, J.C.
that works.
bern
Implied RFE: make Solver warn for non-polygon geometries.
