I installed houdini under linux 8.0, the ip address seems set correct, and the houdini server runs.
Then I use “source houdini_setup_hash” to setup environment. I can type
“hkey” to open application of lincense manager, when I click on “file” to manully set the license, it shut down hkey at once. why??
help me, install hkey.
3768 1 0-
- ykcosmo
- 288 posts
- JColdrick
- 4140 posts
I assume by “linux 8” you mean Redhat 8? This smells like Metacity - the default window manager for v8 - you can't use it with Houdini. Check out this link over at odforce:
http://odforce.net/forum/index.php?act=ST&f=2&t=308&s=5529d8e07d971ca062513790d2a09cb4 [odforce.net]
that talks about getting houdini to run on RH8…it will run fine, you just need to do a little fiddling. So far I've skipped both RH8 and 9 - too much interface hassle - although several Houdini users are using it out there.
J.C.
J.C.
John Coldrick
