reflected light sources
7415 7 0-
- dpz
- 11 posts
- dpz
- 11 posts
- eetu
- 607 posts
- dpz
- 11 posts
thx for the reply but i'm not exactly sure if you really know what i mean. i'm actually talking about reflections and nothing else. to visualize this i rendered a simple example ( a sphere with a grid shaped area light ) in all 3 engines. the material is the pre-built reflective material that comes with houdini; specular completely disabled - reflections enabled.
http://i26.tinypic.com/28shgz.png [i26.tinypic.com]
as you can see the grid shaped area light is reflected in the pbr render. and this feature is enabled automatically by the pbr. ( documentation says: “PBR automatically enables: …, and reflected light sources.” ).
and now my question again: how to enable this manually for the micropoly and/or raytrace engine?
maybe it's not possible at all for micropoly/raytrace .. but what if i want to disable it for pbr? .. so i guess somewhere is this option and i'm unable to figure it out.
thx in advance again. =]
- artzor
- 47 posts
- Alanw
- 320 posts
- Mario Marengo
- 941 posts
- artzor
- 47 posts
thanks mario,
was hoping there might be some secret hidden parameter
it might be nice for future releases to get more of these options built into lights…
check out:
http://www.spot3d.com/vray/help/150SP1/light_params.htm [spot3d.com]
vray lights have options for affect diffuse, affect specular, affect reflections and those are seperate from setting the light to be visible in the render or not…
check out:
to a man with only a hammer every problem looks like a nail.
