I've searched through the boards and found that 1.) this is a common problem and 2.) the commonly suggested fix doesn't work in my case.
Problem I run Houdini Apprentice. Splash screen appears, and then I get the Windows “This program has encountered a problem and needs to close” error. I've tried both build 295 and 375.
System specs
AMD Athlon 3.0 GHZ dual-core
Win XP Pro
4GB Ram
Nvidia Quadro FX 3800
Other 3D apps I run Maya, ZBrush
I've got release 190.38 of the nVidia drivers, so I'm honestly stumped.
Houdini Apprentice 10 Startup Crash
5711 4 0-
- Yantor
- 3 posts
- rdane1010
- 120 posts
- Yantor
- 3 posts
- edward
- 8171 posts
The problem is that you haven't mentioned exactly which of the things you've tried so that we can eliminate the possible causes.
Are you running 32-bit or 64-bit?
Have you tried setting the environment variable, HOUDINI_OGL_SOFTWARE to 1 prior to running Houdini?
Which executable is it actually crashing in? Are you able to start up the “License Adminstrator” from the Start menu?
- Yantor
- 3 posts
