rop render dependencies
7898
5
0
- artzor
- 47 posts
hi all,
i'm trying to hook up some ROP's to render (using hrender) in a specific order…
hooking them up like this… A -> B -> C
it's a three pass render process so i want ROP A to render the first frame, then ROP B, then ROP C. and then the second frame.. so on and so forth…
(as opposed to the default action of ROP A rendering the entire sequence, then ROP B rendering the entire sequence etc)
tried using the frame dependency rop but it doesn't make much sense to me
any help would be much appreciated
to a man with only a hammer every problem looks like a nail.
if you go to Render-Control (button next to Render) you can change the dependency behaviour from Node-By-Node to Frame-By-Frame
Seb
- artzor
- 47 posts
tried that… didn't seem to make a difference
-edit-
i double checked, the default ROP order is set to “frame by frame”
but it doesn't seem to act accordingly?
- eetu
- 607 posts
Try connecting your Rops to a Merge, set the merge node to frame by frame and render that.
eetu.
- artzor
- 47 posts
merge node doesn't work either,
has anyone actually tried doing this with hrender?
maybe hrender breaks rop dependencies or something…
- eetu
- 607 posts
This works for me at least. Although I'm on windows, no hrender here.. :\
eetu.
rop_framebyframe.hip (127.3 KB)
