bevel?
   9479   2   2
How can I start a bevel operation in Houdini?
Hi there,
Take a took at the Extrude SOP - the second input is the bevel profile.
To chamfer existing objects, you can try selecting edges to chamfer and then using the Starburst SOP. Now move the original edges either manually or try the peak handle.
Good luck,
J
jason_iversen, can you explain more about how to use the Extrude SOP to bevel.
coz i tried it, but it cannot bevel, the parameter pane is very complex cry
Thankyou in advance. D
Learning Houdini…
