Watermark appearing on exported movies with Apprentice HD
   4073   2   1
I recently purchased Apprentice HD and enthusiasticly took a couple of renders. Still Images are rendered at any desired resolution without a watermark, but the exported movies automatically get the watermark back.
So I was curious if the “watermark-free” rendering is only for still images. If not, then I'm doing something wrong/incomplete so I'd really appreciate any kind of advice
Make sure your video is HD resolution or less. If that's not the issue, it might be a problem on which video format you outputted to.
Also, workflow tip: Render to images, not movie files. If you crash rendering images, you can start again from where you left off. Crash rendering a movie file and it's start again at the beginning. You can always reassemble your image sequence in a editor/compositor.
-nimajneb
