Cookie problem with box divisions .
   5877   3   0
Dear Sir ;
I want to use cookie op to interset Box op and Spher op . I did selet the " do jitter ' in cookie . It will done .But if I change the BOX op ,I select the divisions in BOX . Then Houdini crashed . Does the cookie op can not be used with Box op in divisions .
Any ideas ?
Thanks advances.
Best Regards,
Winnie
What you're trying to do won't work, no, but you should never get a crash. Can you post what version and operating system you did this with? I can't repro with Linux/6.1.149…
Why do you want to do this? Usually whatever reason you come up with, there's another way to tackle it.
J.C.
John Coldrick
Dear Sir :
I just want to pratiice the UVproject OP in quater of watermelon .
So I use cookie op ,BOX op , Sphere op the do that . ops:
I use win2K + Houdini V6.0286.
Best Regards,
Winnie
Then I would suggest just leaving the subdivs off. You're also running an older version - latest 6.1 shouldn't crash on you.
J.C.
John Coldrick
