Surface from image stack
   5148   4   2
Continued from the mailing list.
Here is a stack of three images. The question is how to make a surface(s) from these images?
Mark
The Trace SOP is pretty ideal for these situations.
You can append a Trace Sop followed by a Carve Sop and a PolyExtrude Sop. On the PolyExtrude, use the Inset value to have a continuous offset from the curves.
Do yo want to animate between the 3 states after?
François
render_dude
Mark
Here's a .hip file which uses the volume VOP to generate a volume primitive.
I hope that with more cross-sections, you'd be able to get a better shape.
You might also blend between two maps (to get interpolation in the y axis).
surfacer.hip.gz (19.9 KB)
Ah! England as it will look due to GW and the water rises.
“everything is coincident”
