OBJ import options
   4611   6   0
played with the program a bit as wanted to see how it worked with some of the models I have saved in OBJ format and found that while it imported them i could not break it up into texture groups and that for the most parts is a deal breaker as far as paying for the program i have a large library of models I have made over the years in that format.
Just writing to see if I am missing something.
You can drop a material SOP and apply a shader to a group
rob
Gone fishing
thanks I will give that one a try.
OK sorry it took a while not seeing what is an SOP. I only get the entire mesh I have not seen a single way that is breaks up. In other apps the model is broken up into separate parts that I can apply shaders too.
Edited by - Feb. 17, 2010 19:21:40
Breaks up ? I thought you want to apply a texture to a group. Why don't you post up a scene file with a small imported obj model of what you are trying to do.
rob
Gone fishing
OK here is the OBJ file. Generally I use messiah and it imports into it and I have separate texture areas. Here is the file and here is an example of what it looks like in Messiah in a render.
beltergirl.hipnc (1.1 MB)
There is no obj object in your scene as the file is just reading your obj off disk.Try locking the file import sop then save your file
rob
Gone fishing
