union polygons
   6540   4   0
I have a bunch of adjacent coplanar polygons that I want to union together to make one big polygon. Any ideas how to do this? See attached file for an example.
union_polygons.hipnc (44.9 KB)
Patrick
try Divide SOP with Remove Shared Edges checked
thanks - that works great
Now I have a slightly more complicated union problem. I want to find that area of a bunch of co-planar polygons that are possibly overlapping, but the total area should only count overlapping areas once. See attached file for an example.
So I need to union them into a set of one or more larger polygons, and find the area of these (measure SOP followed by promote SOP)
So my question is now do I do the union.
union_polygons_2.hipnc (40.6 KB)
Patrick
you can union them with cookie SOP
but not all at once
to do it automatically you need to use foreach SOP
look at the example
union_polygons_2_fix.hipnc (53.5 KB)
Thanks tomas - that is a nice example
Just to get the hang of it, I re-did it in python, using 3d closed shapes instead of 2d closed shapes. See attached file.
union_boxes.hipnc (53.4 KB)
Patrick
