pops - sustain activation
   3606   3   2
HI all,
How do I keep activation in POPs enabled no matter if the value is set back to zero? I am looking for something similar to area CHOP or an accumulate solution (maybe in voppops) My problem in vops is that I'm not able to compare values with the previous frames. Any suggestions are much appreciated.
kuba
Store the attribute values in a new attribute. So to check the previous frames velocities you simply store v in a new attribute.
To do a area lookup for a value you create an “area” attribute and then add the current value to it on every frame. Most chops can be emulated this way, for the other stuff, I usually post process the simulation data, sometimes even in CHOPs.
B.Henriksson, DICE
hi
can You go into detail with this, cause when I try to write the velocity into a new attribute ($previous_v), and watch them in the detail view, the attribute values are identical. v is calulated and written to the attribute value, but having previous frame's values would be great
Martin
You can sustain a value with chops, like described here -> http://forums.odforce.net/index.php?/topic/10797-keep-attribute-value/page__p__69537&#entry69537 [forums.odforce.net]
But would be nice to know another way to do it, maybe with VOPS.
https://vimeo.com/user2163076 [vimeo.com]
