Sprite scale over life
10904 6 2-
- lloydwood
- 107 posts
How can I make sprites grow over their life time? I've tried all sorts of expressions in the scale fields of my sprite POP but it just doesn't seem to work. I'm obviously going wrong somewhere but I can't find the solution anywhere. I want the sprites to go from 0.1 to 10 over their life time. Any ideas?
- tamte
- 9384 posts
- lloydwood
- 107 posts
- memoma
- 15 posts
- old_school
- 2540 posts
You can use that expression directly in a Point SOP after the POP SOP in the scale parameter directly.
You can also use that expression in a Property POP's scale parameter as well.
See the attached example file for a VOPs solution as well. Easiest to build in the control you want.
Note: I use $AGE in place of $LIFE almost all the time. This way if I increase the life of the particles, I don't get a change in behaviour, unless I really want to.
- memoma
- 15 posts
- Soothsayer
- 875 posts
