was trying to figure out how to input data or noise into a houdini camera that would result in realistic camera movements. I appreciate any help you can give. thanks.
realistic camera motion
7549 1 2-
- dshane20
- 1 posts
- betty
- 51 posts
hi dshane20
try going to CHOPs and grab yourself a noiseCHOP, you can combine with many others to get different results.
to export either go to the ‘channels’ tab and specify what channel you are manipulating and then in the ‘common’ you'll see “export prefix”..here just choose which camera you want to effect.
or you can add an exportCHOP at the end of your setup.
hope this gets you going in the right direction
betty
betty
